Connecting PC and Android
NVP
NVP
6 Sep 2007
How can I get my laptop to recognise my Note 10 as just another device/drive on the network, wirelessly?
Seems to be loads of apps but surely you can do it via the network?
Thanks
Thanks, yeh via USB is easy but my cables broken so looking at seeing if it is possible via wifi...
I've tried looking through myfiles, any hints?
Not sure if it's much use but I use an app called WiFi File Transfer Pro.
It gives me an IP address to type into my PC browser and then shows me the contents of the phone. I then do as I need to with any files.
Thanks
Hope this helps
This is what i used it allows you to access files on your pc and a nas ect.
I use Solid Explorer and can access shares on my PC, not tried the other direction - but it works fine.
