Sign up to YouTube premium using a VPN to India, works out to £1.30 a month instead of the £12 a month they charge in the UK.
do you just VPN to sign up or do you need to every time you use?
Just when you sign up. login with your uk account, then connect to India then go to YouTube and click on premium, it should show the price in rupees.do you just VPN to sign up or do you need to every time you use?
Glad you got it working.tried a few servers and finally got it
Thanks
Vanced is filled with nothing but 1 star reviews on the store.
I'm still using firefox with addblockplus, never get youtube adverts, completely forget they exist until I'm at someone elses houseFirefox - uBlock Origin
Android - YouTube Vanced
If YouTube charged a sensible price in the UK (such as £4 a month) then I'd get it locally.
In chrome/windows courtesy of disable hmtl5 autoplay, add-on I never see any adds.
I assume that just breaks the mechanism that would usually cue them up.
That's not the right one. You can only get it from here: https://vanced.app/
I was thinking about this. I'd pay up to £6. That's what it's worth to me.
ok .. maybe, blocking is in ublockO by default now, since that's all I have for chrome extensions ..this didn't work for me, still seeing groups of 2 adverts at the start of youtube clips.
