The butterfly keyboard is garbage IMO. Using it just now and I can't stand it honestly! The keys feel shallow, bottom out with every stroke and despite the claims of it being a more level surface/action honestly dont register unless you're pretty accurate to the centre of the switch. My typing speed is noticeably slower on it and I make more mistakes.
Also, I was eating a biscuit the other week and I think a crumb must have fallen onto it as one of the keys wouldn't work when you pressed it at certain angles. Spent a worried 15 minutes blowing compressed air into the thing and holding it upside down. Seems OK now but suffice to say don't eat near a butterfly keyboard equipped Mac! I reckon you could break the thing irreparably if you shook some salt over it! I'm not even joking when I say that........
No spec bump is worth having to put up with this keyboard! There's a reason Apple rolled out a replacement programme and they no longer sell them.....
I think we should consult the Oracle! (@MacRS4 )
As someone who's clearly had a lot of experience with Apple products what model/spec of MacBook Pro 13" would you recommend buying? Or, having tested it recently, is it worth considering spending the extra money (~£400) to get the 10th generation model if that's an option?
So narrowed it down to the following.
2.4 mbp 13 2019.
or
base 2020 1.4.
Where would you’re money go?
..... It really only leaves a small number of options.
