I finally got around to buying myself a Raceglaze filter this week. It arrived Thursday, and I've just given the car it's first wash using it. Usual washing routine - snowfoam, pressure rinse, two bucket wash, pressure rinse, then apply AG Polar Seal with the pressure washer. I then disconnected the PW, hooked up the Raceglaze filter and rinsed the car with the hose gun, then a final going over with an open hose. I purposefully didn't dry the car like I usually would, except for all the exterior glass. I then just took the car for a quick blast up the nearby dual carriageway, and that seemed to shift most of the remaining water off the body. Then I just gave only the glass one last wipe to get the drops that had been forced out on the drive, then left the car to dry.
So far, very impressed. I had a cup of tea and left the car an hour or so for the last bits to dry and I can't see any water spotting at all. To be honest, most of the water came off during the drive - something I never usually do after washing (except to the end of the road to clear water off the brake discs). However, the bits that remained wet had dried nicely and I couldn't see any residue, despite it being a warm and sunny day.
I will be chuffed if I can get away with washing the car and then giving it nothing other than a quick drive, or even just leaving to dry totally. Drying has always been the bit I hated most about car cleaning, and it always feels like it's the part where I have potential to do the most damage to the paintwork. The car needs a polish next, so next time I might wash, polish and put one a decent hard wax, then aim to touch the car as little as possible for as long as possible, apart from washing with shampoo and a mitt.
I'll also be pleased if this now means I can jsut rinse the car. At this time of year, I find the car regularly looks a complete state within a week of washing, even though it's not been driving, just because it's covered in dust and pollen. Usually, just rinsing that off means a a full wash and dry, or you just replace dust with water marks, but now I can hopefully just plug the Raceglaze in and give the car a rinse down with the hose.
For those interested, I bought the 7ltr Raceglaze unit. I'm aware they do a 14ltr one which might work out a little cheaper in the long run; but I also don't currently have anywhere to hook the filter up permanently, so I figured the smaller version might be easier to lug around on aregular basis. I did consider the 11ltr Vyair units - but I couldn't find a consensus on how these compared to the Raceglaze, whereas I don't think I've seen a single negative response to the RG. So I paid extra for the brand.
However, if's definitely one of those "should have bought one ages ago" type of things. Very happy
