- 24 Sep 2015
Where are you base? I still can’t move my appointment before 17th July (Bristol)
Bucks, near to Milton Keynes.
So you'd have two lines to your house one serving nothing at all. I'd want rid of it, be a right eyesore if every house had 2 lines to it.The BT hub is shipped to you, the person installing the service is from Openreach.
They don't touch the copper line when installing FTTP, that stays where it is.
For a speedtest I'll fire up iperf on a cloud hosted VM which has a 10Gbps connection and see what I get.
I've currently got a RT68U Asus router, however it's not a modem, if I got a modem router is it a matter of just plug and play? Or do I have to request username etc.
Our copper one is really baggy.
I don't have a telephone, all my line has plugged in is the Plusnet router.When I had mine installed last September they used the copper line for the telephone.
I think for new installs now they are trying to move people over to Digital Voice, which is VoIP through the Smart Hub. It makes sense as the PSTN has less than five years left before it's shut down.When I had mine installed last September they used the copper line for the telephone.
That’s make sense, I’m surprised they did not do that with my install as they had to install a new copper line!
My fibre install is a twin cable that has fibre and a thin copper twisted pair for voice only.When I had mine installed last September they used the copper line for the telephone.
September was still before the product launched properly, on your next regrade/contract renewal you'll probably be offered it.
I should have mentioned, my fibre comes over the telegraph pole. It's probably why it's separate cables for you.When they did my install they run a new cable for the telephone line (the termination box is installed on my neighbours property) mine was Originally run in what looked like internal cable, even the install engineer was surprised.
I had to have a new duct installed as the original was not large enough or had debris in.
I am interested in this, I tested iperf on the local network but would definitely want to test the WAN side of the router I bought. I assume you'd setup a cloud hosted VM yourself?
