- 10 Oct 2006
What's BT FON?
It's public WIFI service provided by BT. Every BT router advertises it and you can't disable it on the device you need to do it via the BT webpage. Seen reports of it getting re-enabled after a firmware update on the hub and users unable to get it disabled so glad I can use my existing router without a performance hit as I didn't think my current router had a fast enough CPU to support 1Gbps internet traffic routing.
