Erm? something is wrong with that, what happens when you put some load on it?My Gigabyte 5700XT (none reference) idles stupidly hot. This cant be correct with the default fan curve surely?
Under load is generally OK - particularly hot at the moment, but then again my room is abou 25c! I get around 75-80c at the moment in modern warfare etc.
ASRock 5700XT Challenger D OC https://www.techpowerup.com/gpu-specs/asrock-challenger-d-rx-5700-xt-oc.b7196
I'll update with pics when i have a new motherboard and cleaned my system out, honestly its an embarrassment at the moment![]()
I wonder if its just a faulty sensor then, if the underlod temps are normal.
Edit, humbug had the same idea, but i hadn't refreshed my screen. Would still need an rma, as the faulty sensor will impact fan curve.
Ok so that is odd.... i wonder if its just not reading correctly when idle? can you very carefully.... put a finger on the heat sync when its idle, is it burning hot, not just hot like a cup of tea that's been sat for a few minutes, but really hot?
You'll need to raise an rma I think (or test in a 2nd machine). It's very strange that your idle temps and load temps are the same, doesn't suggest that the cooler is broken.Yep so - touched the heatsink. Red hot. too hot to touch at idle.
BIZARELLY- yesterday, the fan was at 3 RPM (so I guess actually turned off, although I didn't physically check), and the idle temps were 60c. Now they're at 80c idle with 400rpm.
Why is it using 38W at idle? Should be <10W.
Anyone find their Radeon Adrenaline software regularly forgets its OC settings? Also mines stopped successfully detecting updates now - so have to manually check each month.
Weird - it happens to me constantly.
