You would be gaining around 25fps with a 2070super looking at techpower results.
£20 per 1fps now thats Value for money right there!.
3070 will do it if you can wait a bit more. Got to be bonkers spending a 4 figure sum now.What GPU currently available would give me 50fps more in BFV over a GTX 1080?
I get about:
Max: 100
Average: 70-80 depends on map
Lows: 40 when a V2 lands on your head
1440p
Thought you may have lost the plot after wait this longI'm not buying anything... defo waiting it out.
Every upgrade I've made has always been double. So that's what I'm after.
I went 670 (briefly flirted with 670 SLI) then 970 then 1080.
That is on average double each hop.
Just goes to show how poor the new gpus have been for a card that is over 4 years old can still command half the price of what it went for when new. Imagen buying a gtx 480 in 2014 for £200 when for the same price a new GTX 960 was available and gave a 75% improvement.To be fair the 1080 would sell for about £250 (guesstimate). £10 per frame!
Really? A 2070S would give me 50fps on a GTX 1080?
Maybe wouldn’t be 50frames but I bet it wouldn’t be overly far off. A 1080Ti is just under a 2070S and that is already 30-40% faster.
So if you were averaging 70-80 with a 1080 be getting 110ish with a 2070S at stock, more with a decent OC.
Obviously better waiting at this point for next gen though.
The 1080Ti is still slightly above a 2070S.
Bit of a mix and match really as the Super pulls ahead by a fair margin on a number of games but just loses out on a couple others.
Only 2080ti and above but I wouldn't buy now unless super rich or daft.What GPU currently available would give me 50fps more in BFV over a GTX 1080?
I get about:
Max: 100
1440p
3080Ti will probably be silly pricing again and offer probably a 40% perf jump over a 3070 for 2-3x the price, very poor value, though for people at 4k i can see how that might be needed in demanding games.Only 2080ti and above but I wouldn't buy now unless super rich or daft.
Being 1440p as long as i can stay a solid 80-90+fps I'm happy with it, of course the more the better until it barely makes a difference anymore when you start getting over about 120.
Yeah, running 1440p it's likely that a regular 3080 will be a good buy without needing a Ti.3080Ti will probably be silly pricing again and offer probably a 40% perf jump over a 3070 for 2-3x the price, very poor value, though for people at 4k i can see how that might be needed in demanding games.
The number of people willing to pay $700 for 40% more performance than the 2080 Ti is probably a LOT higher than number of people willing to pay $1400 for that same performance.
But if they can sell 10% more performance than a 2080Ti at $700 and 40% at $1400, then they can capture both parts of the market using product differentiation.
