 - 14 Aug 2018
You seem to have lost the plot. A CLC is made up of much than just rubber. You will see that it has joints in the metal construction, joints between the hoses and radiators, joints between the rubber hoses and block assembly etc.Show me where your science is wiseman before you go off on one. Honestly. so far you have just referred to some junkie on YouTube and nothing to backup your assertion.
You seem to be under the false notion that after years of the water being continually heated and cooled that non of the H20 molecules will find a way out through the many joints etc.
What you will find is people like @Acme who had a CLC for ~5+ years tell you that the performance of their particular CLC got less because the amount of liquid inside was not the same volume as when it was brand new. This is a simple fact; you can choose to believe it or not.
I personally know of 5 original H100i's from 2011 that eventually dropped in performance considerably due to the lack of liquid that was inside. It is one of the reasons that my AIO has a fill port on the side. I like to top it up every 12 months or so.
