- 18 May 2010
- London
Why would Nvidia cards "not cut the mustard" if they are at least 40% faster at rendering with 4x faster ray tracing?
If their not available
New cards are likely around the corner, so I'm not buying now anyway. I have no big reason to have one at the moment, only for one game right now, so I'm happy to wait a bit.To be fair, my 1080Ti offers 80-90 fps in most games, so a 2080 would probably be just fine for you.
Yes, though i imagine even a 3070 would do very well providing these are actually a good jump in performance, which it seems like they will be. If the 3080 is only a little more expensive then i will look at it depending on perf/cost.Yeah, running 1440p it's likely that a regular 3080 will be a good buy without needing a Ti.
I just want the release to be over with now.
Will probably be able to get the 3080 up to the speed of a 3080ti stock with a good overclock on water.
What makes you think that?
Overclocking the Nvidia cards only gives a couple of % now days.
Yeah you certainly can't get a 2080 to 2080ti performance, it just doesn't have enough cores.
As for the gains they are not as bad as you make it out. I got an extra 10% performance on my ASUS Strix 2080ti without having to replace anything - it's just air cooled. You can actually get 15 to 20% extra performance on a 2080ti with a custom loop
Indeed. I want to see some that show a 3070 keeping up with 2080Ti rasterisation performance and handing its arse on a platter with RT performanceat least we are getting to see wee things now if true. all wee need now is some benchmarks and we are sorted .![]()
Maybe it's the Chinese knockoff version!.
About that much.
I don't see any power plugs either.
