well, the 2080 wasn't better than the 1080ti so it's standard really.
Not true, the 2080 is a better card than the 1080ti. It's mostly those who bought a cheap 2nd hand 1080ti that are desperate for it to be, from my observations.
The 2080Ti is undoubtedly a better card, just not by the large margin that previous new high-end generations were.Not true, the 2080 is a better card than the 1080ti. It's mostly those who bought a cheap 2nd hand 1080ti that are desperate for it to be, from my observations.
Like i said before, they give less and people expect less the next time.. seen quite a few saying similar before.If 1 out of the last 10 generations of Nvidia GPU's does not have significantly improved performance does that really make it 'standard'?![]()
Yes, the same principle obviously applies to anything not just GPU's.Like i said before, they give less and people expect less the next time.. seen quite a few saying similar before.
I keep seeing 3090 listed in these rumours. Think they’ll go for that instead of 3080Ti?
I think a 2080 can hit speeds of 2080ti with overclock.What makes you think that?
Overclocking the Nvidia cards only gives a couple of % now days.
no difference lololol you must have been using a h50 or h80. Custom watercooling blows the best air setup clean out of the water. Period.My experience of water cooling GPU's (1080ti and 2080ti) is that there's actually nothing in it, its just quieter on water, air coolers on 100% are basically going to give you whatever the chip is capable of, like maybe on a warm day it helps you hold those clocks where an air cooler would start hitting thermals, but out side of 30C+ ambient days, no
If the 3080 is less performance than 2080ti I will not be buying.From that article:
"According to rumors the RTX 3080 will ship with a GA104 GPU, and replace the existing RTX 2080 with 48 SMs (3072 CUDA cores). This is very slightly more than the RTX 2080 at 46 SMs. Coupled with higher performance throughput and improved RTX cores you are looking at a significant performance increase if this turns out to be true - in fact, it is estimated to be just slightly less in performance than the RTX 2080 Ti current generation flagship. The RTX 3080 GPU will be coupled with 8GB/16GB of vRAM and a 256-bit bus width."
That would be disappointing if so. 3080 less performance than a 2080Ti? I thought the expectation was that the 3070 would be slightly less than the 2080Ti.
NVIDIA RTX 3080 graphics card to get the GA102-200 treatment with 4352 CUDA cores, 10GB vRAM, and at least 15 TFLOPs of graphics horsepower?
https://wccftech.com/nividias-rtx-3...ght-ship-with-ga-102-200-and-4352-cuda-cores/
And that is why we love WTFtech, less than 3 hours apart we have two posts that seem to completely contradict each other.![]()
If the 3000 series gaming cards where only 3 months away wouldn't of Nvidia done more of a gaming focused announcement like they did for the data centre Ampere a few months back?
