That would be majorly disappointing to say the least!From that article:
"According to rumors the RTX 3080 will ship with a GA104 GPU, and replace the existing RTX 2080 with 48 SMs (3072 CUDA cores). This is very slightly more than the RTX 2080 at 46 SMs. Coupled with higher performance throughput and improved RTX cores you are looking at a significant performance increase if this turns out to be true - in fact, it is estimated to be just slightly less in performance than the RTX 2080 Ti current generation flagship. The RTX 3080 GPU will be coupled with 8GB/16GB of vRAM and a 256-bit bus width."
That would be disappointing if so. 3080 less performance than a 2080Ti? I thought the expectation was that the 3070 would be slightly less than the 2080Ti.
In other words the 3080 is now the new xx70 card with the old xx80 price tag? They will get a lot of flak for going this route.Makes room for a 3080ti and a 3090ti![]()
. I've had 1080ti SLI for 3 years and it works in the majority of games I play and it destroys (as in grinds into dust) the 2080ti in the games that support it
