The 3800X uses the same chip.
I think the 3800x single core boost is lower and generally needs more voltage. I don't think it's the same bin.
I doubt it else the 3800x would have a max boost of 4.7ghz,Im pretty sure the 3950X is 2x3800X chips.
I don't think that's the case due to how efficient the 3950x is considering the core count vs the 3800x. I wouldn't be surprised if the 3800x is using leaky silicon.
All the way from Threadripper down is "junk" silicont didn't make Epyc
Lol, heard that many a time and of course it's complete rubbish. Epyc only has to to meet voltage, TDP and clock speed set for it. No company running Epyc is going to enable PBO, XFR or overclock it, they will just run it at stock.
Everything "down" from Epyc is almost certainly binned, because it has to be that's the philosophy behind the idea of chiplets.
Low leakage usually IS better silicon though. The improvement in process/yields allows for clock bumps like this. AMD wouldn't launch a refresh unless they enough good die to trickle down
Are any zen 2 owners actually going to upgrade to these?
They look decent for a proper upgrade, but I cannot see the point in upgrading from the current CPU’s to these. Especially seeing as Zen 3 is coming soon(ish).
AMD Ryzen 7 3800XT Spotted in Ashes Benchmark: 10% Faster than the 3800X
