Why is it such a big deal that they replaced Edge with Edge? I'm missing something obviously . You can still change it. Google still nags you to use Chrome instead whenever you visit a google site. What's the issue?
When a smarter and better person than you tells you something, just accept is a fact and don't argue.
Ok?
From UUP dump - I hope I'm allowed to link to this, as I don't think the site is 'dodgy'.
That's the same one I used, only I chose en-gb language and just selected the Pro edition. For some reason the Enterprise wouldn't install.I'm running the cmd now to fetch Feature update to Windows 10, version 20H2 (19042.330) amd64 and since they coming from Microsoft servers it should be ok.
But Edge was already there. I get it might be annoying if you're doing an inline upgrade and you already have another browser installed but just let it set edge up then change the default back. Then it's dealt with. There's plenty to criticise MS for but this is really nothing. They way that article is written though, you'd think it was the end of the world.
about 30 seconds after booting it suddenly popped up with the "Welcome to Windows" screen which I couldn't skip and had to go through a few choices at which point I could get back to the desktop but for the next ~10 minutes various OS components were busy in the background using around 70% CPU so my video was frequently stuttering and occasionally dropping to low bitrate before recovering again, etc. I never have that experience with my systems on Windows 7 ever - unfortunately the hardware for my media setup doesn't have drivers for anything older than 10 and Linux/Android isn't an option with some of its usage.
It took longer for you to write that post than it does to change your default browser back to whatever it was you were using before the upgrade. Yeah it would be better if you didn't have to. But come on.
I takes me no time at all to hammer out long posts I probably posted about a dozen others at the same time.
I think they removed it, a little google shows away to get it back but didn’t work for me. I did a clean install on a laptop a few weeks ago now and can not get the auto login to work as the options now removed from the screen you mentioned.New windows 10 install and can't automatic login?
I go to Run and enter netplwiz and I don't see Uncheck Users in there? Was this changed in the new win 10 2004 update? I can't auto login on this new wins install?
I'm struggling to remotely update a netbook with a 32GB eMMC drive from 1511 to anything above.
Can't delete some C:\OSRSS folder which is ~3.3GB in size and C:\Recovery which is ~2.3GB - that space could be used to force the machine into upgrading. Whoever thought that 32GB would be enough for a Windows 10 installation should have their heads examined.
