- 25 Mar 2004
- Fareham
That is how I read the spec too but probably best to wait for someone with a bit more knowledge to confirmWith regards to the rotary isolator, my installer mentioned that it is quite common for installers to install one but it is unnecessary in most cases. Mine just has an isolation switch behind an external socket cover which looks better IMO.
Ah, I must be blind. I missed your new quote with the 3x 1.8kw units and the fact you mentioned the condense for the master bedroom being routed in to the guttering. That will give you a nice neat install.
I did think the external unit was meant to be underspec'd for the best efficiency but I have no idea how true that is or if there is much saving in doing that. I bet on a really hot day/week you would rather be able to cool the rooms a lot quicker.
The all most important question.... when can they do it?
*edit* I've just checked my external unit, mine is the exact same model number.
Very cool, and your external unit looks to be spurred off a plug like mine would be so that means mine should work the same as yours (technically anyway).
As for when, they are coming back today to arrange some final minor details and check the length, but from what I saw that unit can have a run of 25M to the internal units, so should be OK.
For install date, looking at a couple of weeks away at the soonest
