Caporegime
- 11 Mar 2005
- Leafy Cheshire
Don’t forget to put the fire nut on before doing the flare!
Lost count amount of times I have done this
Do you own a vac pump?
I really need to put one in my living room / dining room - I might cheat and get some one to do the installation.
I will forget, just you wait.
Not got a Vac pump, probably going to rent a good quality one instead of buying a cheap unit.
Do you usually put anything on the thread / flare joint?
