Well, new start menu is perhaps pushing it a bit far Cleaner looking start menu might be a better description lol
Visual tweaks that should have been done I dunno... nearly 6 years ago.
It wouldnt matter when they did it, you'd still complainVisual tweaks that should have been done I dunno... nearly 6 years ago.
LOL
Contrary to the image I'm sure some get I don't just complain for the fun of it.
Pussy
Just take an image of your system if it fails then revert.
Can you remember Ghost 2003? You could image a system in 3 mins flat.
I might see if I can image my SSD and keep it on my external drive and see how long it takes.
Could do, could even clone it.
Clone it, image it same thing dingbat. You should then update and if it works great! if not just restore. I'm just looking for a nice piece of software now with restore functions.
Onboard sound?
Soundblaster Z. Going to try uninstalling it and then reinstall the driver first.
Yeah, if it goes **** up, and i can't boot, i can just reinstall from me USB, whack macrium straight on, and just clone back
U having any probs on 2004 ?
+1This makes me worried like the 1903 incident. I'm getting so tired of Microsoft arsing about with soundcards.
Not a single issue on 2004. I'm just cloning it now using Clonezilla. One of the best ones out there and USB bootable.
My image is 46GB and it's took 14 mins to make the image so far and it's doing a data check which is 5 mins done out of 10.
I am now formatting my machine with latest MS ISO for a clean install.
+1
That's mostly why I am holding well back from 2004, with my Creative X-Fi Titanium.
