So I'm trying to overclock my 3600 to 4.4 or even higher Ghz. So far I managed to get it to 4.2Ghz at 1.3v (smt disabled), however I heard that if you go above 1.3v on ryzen 3xxx, it will noticeably reduce the lifespan on the CPU. Is this true though? Cause from some people I hear they go up to 1.4v with no probs.
My cooling is fine I think, I have a Noctua NH-D15S CPU cooler, and I have also installed 2 system fans that push cool air into the CPU, in addition to having a fan on the otherside of the case that pushes air outside of the case. I get about 45 degrees on idle and 50-60 when CPU is used a lot.
