Don
- 20 Oct 2002
- Oxfordshire / Bucks
Worth mentioning too that continued upkeep on the protection will also reduce the frequency required to clay in the future.
thats good to know
thanks
Honestly, I would throw the old stuff away. I had an old bottle of super resin polish and it looked like it had split, no amount of shaking would get it back to how it should look. I'm not sure how any of the chemicals would react with a car being well past their best, might be wise to play it safe
Aerospace 303 is good stuff, I've liked it when I've used it in the past. I've used GTechniq glass ceramic coating on my glass (after polishing/cleaning it first, it was a kit) I swear by the stuff, it's been superb.
I deffo pay extra for HAPPY ENDING
It has likely etched the clearcoat, so the only real way to deal with it is to try to polish it out.Sadly I have left some bird poop on my car for way too long and when I've eventually got round to giving it a proper wash there appears to be some slight damage to the paint/lacquer. What can I try to reduce/remove it?
Curious about these, do they really remove the need to dry? How long do one of these filters lastMy RaceGlaze filter arrived today, I can't wait to get it plumbed in tomorrow and give it a whirl, probably Friday from looking at the weather report!
@Muska , how goes a race water filter help clean your car ? what does it do ? I've never heard of it lol![]()
