- 24 Sep 2015
My engineer disconnected my old line from the pole before connecting the fibre line to the CBT.
Did you move to BT Digital Voice as part of your move to FTTP?
Nope.Did you move to BT Digital Voice as part of your move to FTTP?
Ah. I was wondering about that. Makes sense. I didn’t think to check the new NTE5. I was too busy running every speed-test known to man.Ok, so I guess the cable that's running from the pole has both fibre and copper in it. I think that's known as hybrid cable.
The copper line will be connected back to the same point as the old cable was so I would expect that your VDSL service was still active via the new NTE5.
Just noticed in the SH2’s Technical log that a new firmware was applied during that reboot (v0.17.01.12312-BT).Rebooted or factory reset? Did you need to contact the BT forum mods?
Yip.That's essentially the fix, not all routers were getting it automatically, they had to manually trigger mine.
Are your speeds still ok?
Managed to get my mums new FTTP service on the Full Fibre 100 (150mbs) for £34.99pcm from here - bt.com/newfullfibre
£105 topcashback on top too
Pretty happy with that but a bit miffed some have gotten it for £29.99pcm!
That's pretty good, How did you manage that?
If you went through Topcashback, what option did you select?
When I go through TCB when it directs me to BT site price goes up £39pm
On the BT Website, they are offering a Fibre 100 product for £39.00 per month.
I have just moved into a new property and I signed up with them and went with the Fibre 2 Product up to 80Mb
If I log into my BT account I can upgrade to the Fibre 100 product but only with BT Halo added on which bumps up the cost to £60 per month.
I don't want BT halo, can you upgrade without?
Full Fibre 100 for £29.99 here mate: https://www.bt.com/campaign/full-fibre-240
I signed up with them for the Fibre 2 product though, will they upgrade me?
One for the box and one for the Smart Hub?
