- 28 Nov 2011
So is it worth turning on HAGS in Windows 2004?
Running a 2070 Super at 1440p.
NVIDIA Studio Drivers provide artists, creators and 3D developers the best performance and reliability when working with creative applications. To achieve the highest level of reliability, Studio Drivers undergo extensive testing against multi-app creator workflows and multiple revisions of the top creative applications from Adobe to Autodesk and beyond.
Applications
This Studio Driver provides full support for the new DirectX 12 Ultimate graphics API. This includes support for DirectX Raytracing (DXR) version 1.1 as well as support for mesh shaders, sampler feedback, and variable-rate shading (VRS). Additionally, this driver supports Hardware-accelerated GPU Scheduling when used with the Windows 10 May 2020 Update.
In addition, this driver adds support for Vulkan 1.2 as well as optimal support and bug fixes for the latest creative applications from Adobe, Autodesk, Blender, Chaos, and Corel.
From what ive read/seen, id say no, only makes a slight difference in about 1 game, and shows nothing/negative in lots of others.
[Shadow of the Tomb Raider][DirectX 12]: The game may crash when launched with Hardware-accelerated GPU scheduling enabled.
[Death Stranding]: Texture corruption may be observed during gameplay on GeForce GTX 16/RTX 20 series GPUs
NVIDIA Control Panel does not display the native resolution of some HDTVs with invalid timings
Some games may exhibit random freezes that lasts for a few seconds during gameplay.
Some displays may show a green tint when Windows Night Light is enabled
[Forza Motorsport 7]: Game starts to stutter after racing a few laps
[G-Sync Compatible] Adds support for the Samsung 27" Odyssey G7 gaming monitor
It's safe, why? Because ManualG (Nvidia Rep Support) Is a full supportive member
And you're welcome!
EDIT : If it scares you that much, I found the Nvidia link
https://nvidia.custhelp.com/app/answers/detail/a_id/5046/kw/
Another hotfix.
We'll be getting the Nvidia, fix yer drivers vids before long, as they've been broken for months and months now![]()
Used Slimmer on the 451.85's, been a solid driver so far, can recommend.
NVIDIA STUDIO DRIVER 451.77 Supported Products
NVIDIA TITAN Series:
NVIDIA TITAN RTX, NVIDIA TITAN V, NVIDIA TITAN Xp, NVIDIA TITAN X (Pascal)
GeForce RTX 20 Series:
GeForce RTX 2080 Ti, GeForce RTX 2080 SUPER, GeForce RTX 2080, GeForce RTX 2070 SUPER, GeForce RTX 2070, GeForce RTX 2060 SUPER, GeForce RTX 2060
GeForce 16 Series:
GeForce GTX 1660 SUPER, GeForce GTX 1650 SUPER, GeForce GTX 1660 Ti, GeForce GTX 1660, GeForce GTX 1650
GeForce 10 Series:
GeForce GTX 1080 Ti, GeForce GTX 1080, GeForce GTX 1070 Ti, GeForce GTX 1070, GeForce GTX 1060, GeForce GTX 1050 Ti, GeForce GTX 1050
No 9 series...
I'm on a 2060 super now , no idea why people say amd's driver and software suck this nvidia control panel looks like something from 1999
been so long since I was nvidia cant even remember the last nvidia card i owned
0 crashes or issues thus far (after a clean windows install) solid and why I didn't go 5600xt or 5700 xt got it bstock for £306
