Jesus wept, son. HAUL!
All of the toys! Now question for you... would you like a BL touch, ender 3 bracket etc to go along with that boot loader. All new and unused?!
It was Great to meet you as well Vince.
Loved our chat about things
I hope you find the Core XY and parts to your liking.
Have fun with it all
It's the Marlin firmware....will get a link for you.
edit= https://www.thingiverse.com/thing:1001065/files
@Vince Possibly a silly question for you. Various ads keep pushing the BL Touch at me. I'm not biting but just curious as to how it works. In bigger CNC mills, the machine is already fixed level but the probe is detecting the edges of the part and then running the coordinates of the model relative to that. Does this probe the bed and then mathematically adjust for the fact the bed is not level (ie move the z axis up and down as it traverses around the bed) or does it just probe each corner and then whinge at you to move the adjusters until it goes beep or something?
Just trying to work out how it would be any better than a feeler gauge or a dial gauge.
I think its the first, probes the bed then adjusts for not being entirely level.
Somebody will correct me if I am wrong as I am pretty much a noob myselfI think its the first, probes the bed then adjusts for not being entirely level.
Frankly the rest of the firmware is fairly simple and easy to get to grips with
Ok - I think there is an offset for BL-Touch in the firmware which tells the distance from the hot end both vertically and horizontally. That's the bit I really need to get to grips with!Frankly the rest of the firmware is fairly simple and easy to get to grips with
When I was sorting last night I found some 2100 256step drivers hiding away in one of those boxes. Those drivers look to be an awesome driver from what I can see on the interwebz. Looks like I have a million decisions to make on what to do![]()
Cool, cheers to both of you for the educationVince is correct, it will probe the bed on a set number of points and then make adjustments as the print is proceeding
You weren't kidding either there is literally all of the stuff!! I have to ask, there are about 4 bowden setups in there did you ever go full bowden with it?
In a perfect world, your print bed is perfectly flat so all you need is a consistent gauge to tram the bed up with the hot end. The nozzle is then the same distance from the bed at all times. In reality, print beds can be warped in some way so even if you tram properly at your corner points, other parts of the bed could be too low or too high.Just trying to work out how it would be any better than a feeler gauge or a dial gauge.
Sooner or later I'm going to have to sort out my bed. BLTouch was an option, so I'd graciously accept your offerwould you like a BL touch, ender 3 bracket etc to go along with that boot loader. All new and unused?!
Thank you
I was going to buy a resin 3d printer today.
But all the faffing about after has put me off.
The fact that the stuff is toxic to touch and to breathe put me off!
I have exactly that problem with mine in that the bed is bowing upwards by a surprisingly large amount (like 0.2mm), so when I have a perfect level at the 4 corners, my hot end will actually snag a print or even scrape along the bed as it travels, and causes some serious elephants foot too as my first layers aren't flat. I'm compensating to a degree with Z-hop when slicing in Cura, but it's not ideal.
Which brings me to...
Sooner or later I'm going to have to sort out my bed. BLTouch was an option, so I'd graciously accept your offerThank you
I also have the ender 3 pro bed with 3 point bed adjustment and all that good stuff, (genuine Creality parts) which is now yours. That will sort your bed out for sure
care package on route this weekend!
You, sir, are a legend. By all means keep the springs and wheels, I have my own upgraded parts here.
Now you have no excuse to start the upgrades!
Bloody hell.
Glad you posted that now...
I thought about bowden, but direct is better if your using Flexi
Think I gave you some flexi as well? Some of the filament is a different size, so keep an eye out for it.
