LOL those release notes. Are they even worth bothering withseems like all installer improvements as opposed to any performance benefit
New drivers released :- 2.04.28.626
Release Notes :- https://www.amd.com/en/support/kb/release-notes/rn-ryzen-chipset-2-04-28-626
Strange this is an older version of what Asrock have. I tried to install this but it said I already have a newer version.
I'm not sure if its me but my system seems a touch more responsive since I installed the new drivers. Possibly imagining it mind.
Damn, I only did a fresh install of windows and chipset drivers a few days ago. Any release notes?New Chipset drivers released today:
AMD Ryzen Chipset Driver 2.07.14.327
Source
AMD Ryzen™ Chipset Driver Release Notes (2.07.14.327) Highlights
Release Highlights
Fixed Issues
- Initial support for AMD Ryzen 4000 G-Series Desktop Processors
- Driver change details added to release note
- Windows 10 only Release
Known Issues
- Moving installer window during install process may cause installer window to flicker/move around the screen
- Installer may fail to launch if executed from a folder name with non-Latin language
- Workaround: Execute the installer from C:\AMD
- Manual system restart required for Windows® systems configured with Non-English OS Pack
- Windows Installer pop-up message may appear during install
- Installer may not downgrade to older version
- Workaround: Manually uninstall latest package from control panel and then install older package
Used to be that way maybe 10 years ago. Now I don't care unless I know there is something that will either fix or improve something. Same with BIOS's. My BIOS is from last year. All the new one's would not make any difference to me from what I can see so why bother? There is a saying, don't try to fix it if it aint brokeI don't know how you can do that. I've GOT TO have the latest...
Used to be that way maybe 10 years ago. Now I don't care unless I know there is something that will either fix or improve something. Same with BIOS's. My BIOS is from last year. All the new one's would not make any difference to me from what I can see so why bother? There is a saying, don't try to fix it if it aint broke![]()
We live in a post spectre meltdown world now, one where even the bios needs security updates.
The latest ones patch the SMM call out vulnerability.
or if it ain't broke, hose it!
AMD is aware of new research related to a potential vulnerability in AMD software technology supplied to motherboard manufacturers for use in their Unified Extensible Firmware Interface (UEFI) infrastructure and plans to complete delivery of updated versions designed to mitigate the issue by the end of June 2020.
The targeted attack described in the research requires privileged physical or administrative access to a system based on select AMD notebook or embedded processors. If this level of access is acquired, an attacker could potentially manipulate the AMD Generic Encapsulated Software Architecture (AGESA) to execute arbitrary code undetected by the operating system.
AMD believes this only impacts certain client and embedded APU processors launched between 2016 and 2019. AMD has delivered the majority of the updated versions of AGESA to our motherboard partners and plans to deliver the remaining versions by the end of June 2020. AMD recommends following the security best practice of keeping devices up-to-date with the latest patches. End users with questions about whether their system is running on these latest versions should contact their motherboard or original equipment/system manufacturer.
Failed to install for me with a 3900X on X370.
