- 15 Sep 2009
- Birmingham
Both have the same name and in Windows and when I go into the graphic cards adaptor settings in the Device Manager, are against 'Generic PnP Monitor'
One on integrated Intel graphics and the other on nvidia drivers 451.67
Mine doesn't flicker while being set to 144hz and freesync turned off, but only after turning off freesync and then restarting my PC.edit- just tried 144hz with and without hdr and no freesync but the flicker remains. Got a club3d cable in the post, if that doesnt fix it, it may have to go back
In the Dutch forum someone already tried the club3d card but unfortunately without result.Mine doesn't flicker while being set to 144hz and freesync turned off, but only after turning off freesync and then restarting my PC.
As a follow up to my last post it actually annoys me that it occasionally works as sods law it will work perfectly when if it gets RMAed for a bit and I will get told there’s no problems.
OK? You gave up very soon. Although I can understand. I don't think it can and will be solved by not returning it.
Just curious what your next screen will be?
I actually don't know atm.... I have a Lg34gn850 on its way. But it's way more I would pay for a monitor. At least I can see if it's worth almost double the price. It's IPS vs VA.
Also the Coolermaster GM-34CW i have been looking at. Same panel as Iiyama.... But no reports of flickering. But also a third more expensive than Iiyama.
Hi @Justdigit let us know how you get on with the LG - am very curious if the extra £ is worth it, as you say. At the moment I am thinking whether to order the Flat IPS Iiyama GB3461 and be prepared for another (longer?) wait. I really want an UW for work reasons more than gaming (but gaming is a bonus!). I prefer a curved screen also - but for my budget this is not going to be an option, if I want freesync and no flickering etc. At the moment I am thinking perhaps I accept the Flat screen Iiyama and consider upgrading in 2-3 years for a curved screen that can also do HDR (HDR600+). The backup was going to be the non-UW Dell (S3220DGF) - but the possible risk of flickering has put me off, given the Iiyama experience. So currently a non-UW option might be something like the new Dell S2721DGF - which looks interesting). I really did like this Iiyama screen for the value, looks, even the joystick menu (with blue LED which fits in with my theme!), good paper specs etc. Just so frustrating about that flicker! It was a deal breaker for me. I really hope Iiyama put out a fix for those that keep them, soon.
@markwilliams82 - really pleased both of your screens are working as intended. Thank you for the support answering everyone's questions. All the best.
