Yeah that is a neat feature and underrated as well. 80C is overall temperature I assume, and not junction?
When I go into advanced fan tuning I cant set zero rpm so just went with changing Max Fan speed % this way the fans also stop when doing light tasks
85% is the sweet spot, you'll get massive benefits and I defy anyone on a 4k monitor to notice as the Radeon Image Sharpening is IMHO the greatest thing ever and so underated, it's fasntastic in what it does quality wise and if you reduce it you just cannot see any difference. So, much better than nVidias version which I've seen and just makes things blury.I havent played for long but it went to around 80c this is on default fan curve
Just tried 1440p (2176x1224) 85% scale with Redeon Image Sharpening On couldnt notice any different in quality ran the benchmark in World War Z it went from 129fps to 150fps which is really nice boost, Really impressed with this card comes high clocked and trixx software![]()
I always have mine set to 85% scale in AMD drivers and happy days, running everything 4k and more fps with no noticiable side effects, win win!
Out of the box clocks are 2059 at 1.2v, which is one of the lower out of the box clocks I've seen, however i was easily able to max out the core clock at 2150Mhz at around 1.135v. That results in around 2055Mhz clock in game.
I set it to +50% as soon as i started tweaking.Did you touch the PL at all or left it at stock?
Why do you ask?Ahhh ok, thanks @LtMatt
Why do you ask?
)What's the stock clock/voltage as show in Radeon Software?Been trying to undervolt my GamingX but it was having none of it, will try again whilst increasing the PL (when it cools down a tad)
