Still want to build in this case - but with the rumoured TDP of the new cards, it scares me![]()
External radiator
External radiator![]()
I certainly appreciate the ingenuity - however I prefer more clean set-ups. Cool concept though but kinda defeats the H1 for me, at least.Yup, this all the way.
I run a quad (4x120mm) monsta rad (so quite thick) using noctua fans. GPU and CPU sit at 40oC gaming (this is the temperature I have set fans to very gently start ramping up, Set to default to minimum speed below 40oC). Using CPU temp atm, but going to hook my corsair commander up and run based on fluid temp post radiator.
If you want to watercool then go external.
Old pic, cables are much tidier now.
Always horses for courses. Whats right for me someone else will not like.
Went from a phantek Enthoo primo to this... The small footprint on and under desk works for me, but as you says its not for everyone.
I can cool whatever hardware is thrown at it, with 2600 overclocked to 4ghz and a 1080 overclocked (+250/+200 from memory) I cant get either cpu or gpu over 41oC with silent fan settings.. Perfect for work and gaming.
When it comes apart next I will be adding dry disconnects and slightly longer hose, make it very easy to move/work on as needed.
What are people thinking with the new 3xxx Founders cooling in this case? Would hot air blowing out of the IO side just get stuck flowing around the case and increase temps?
I think the FE cards will be a no-go for this case TBH. There's already some concern with the cooler design and sandwich layout cases. The H1 has the added problem of the rear IO being enclosed. With the FE venting through the IO panel, it's likely to suffer some of the problems seen with blower cards.
