Got busy building the printer last night on the dining room table (it's 30c over here and I have no aircon in the attic where my PC is so didnt fancy doing it up there yet). All fairly straight forward, just the belt was a bit awkward and had to google how to tighten the carriage.
Elected to not use the glass plate I'd ordered and just go with the magnetic bed.
Used Chep's bed leveling gcode to set the bed up. Simple and done in 10mins (seems I have a nice flat bed
Started a supplied sample print. Was going nicely but then noticed the bowen tube kept slipping off. Didn't realise that there were 3 different sized blue clips available and I'd used the wrong one.
Had to pause the job to refit the tube a couple of times. Looks like  the printer doesnt like to be paused as, on the second resume, the filament coiled up and went everywhere.
Not too worried as I still need to dial in the temp settings and it was bed time anyway.
So far, I'm cautiously optimistic that this is going to go well. Will try the boaty test bench tonight and see how it goes.
Can't wait to fire up 3ds Max and start designing stuff
@Cenedd it has the standard springs on it, will probably upgrade those fairly shortly but seems ok so far.
