This might actually be the most painful and convoluted install ever. Three and a half hours in, and 60GB is done Decompressing the files seems to be taking more time that downloading them...
Just learnt a lesson - don't plug a usb device in while it's downloading - made mine freeze, had to restart the game, but luckily started from where it left off.
Dropped down by 50gb when plugged in my old wingman controller.....but disaster averted as above on the restart.
Mine stopped updating after I downloaded 16gb (because I told it to) then when I relaunch I have more options like graphic settings and it lets me play. Does that means it's streaming the data? I'm not entirely sure how to carry on downloading.
Despite being minimised when it was downloading it's also running my GPu at 100%.
I'm running a 4770 equivalent Xeon and it's perfectly smooth with my Vega 56 at 1440p on the default 'High-end' settings. GPU usage at 99% mind, and occasional high fans.
@phil-k Other than not having to deal with microsoft store and potentially having all your purchases in one place if you are a heavy steam user, apparently no difference. All steam will do is launch the launcher anyway.
Advantage of MS store is play anywhere, multiple family instances playable concurrently.
