@twoodster the CPU overall usage is largely irrelevant though if a single thread is hitting 100%... The rest of the CPU could be sitting relatively unused but you’ll still be limited by that one thread. If you’re interested then have a look at what all threads are actually doing, not just the average usage.
As above try enabling hardware GPU scheduling acceleration. It will move some load on to your GPU from the CPU... it’s a new windows feature in the latest update.
If you haven’t tweaked your ram and infinity fabric settings using something like DRAM calculator for ryzen then you are also leaving potentially quite a lot of performance on the table.
I did just update Windows and turned on GPU scheduling acceleration. Unfortunately still no difference to framerates though. No matter the settings I seem to be stuck on the same framerates
