For those who are having issues installing via Xbox game pass - myself and a friend encountered a issues both of these we fixed after a fair amount of frustration.
Issues - installer was stuck on splash screen with blue bar not moving indefinitely.
This bizarrely fixed it for me , logout of xbox game pass , use a vpn to connect then log back in.
A friend of mine had the same issue however the above didn't fix it, he found out that his virus checker was causing the issue.
*bear in mind only try this if your using something other than the standard microsoft defender virus checker. i.e. Avast , Mcaffee
The only way he could fix it was to do the following :
re-install xbox game pass client then install FS2020.
It turned out his virus checker was causing some serious problems and even disabling it didn't fix it; he had to uninstall fully!
Ofc I can't guarantee this will fix it but hopefully it may help out someone.
- uninstall FS2020 , delete from game pass.
 - uninstall the xbox game pass client
 - uninstall his virus checker.
 nice one. Can I ask which version of FS did you get? I'm struggling to verify the version that the MS store claims I have. It says premium on the tin but is there anyway to find that out in game?
