- 22 Sep 2008
- Burscough
Its not available in this version but the devs have confirmed they are working on a replay system.
That's good to knowIts not available in this version but the devs have confirmed they are working on a replay system.
LOL!
That's what time acceleration was for in X Plane 11! Longest flight I did was Newark to Manchester and I left it on overnight for a laugh and landed it on my alarm wake up the next morning.
Most of my jet flights are short within Europe and I use time acceleration to cut out the boring cruise, otherwise its just an exercise in staring at dials!
. I couldn't sign up to the cheaper beta for £1 (then £3.99 a month), maybe as already done a trial before. If good, and if I like flight sims, I'll cancel the trial within the month and buy the top end version for lowest price I can find. I don't spend enough time gaming at the moment to justify a monthly fee.100% Joystick, controller will work too but joystick or yoke will give you much better experience, doesn't need to be hotas as long as there is 1 throttle on it.What type of controller would be best for this? An Xbox controller type of thing or Joystick? I only usually use keyboard and mouse for other types of games.
Not done low altitude plan but have done direct plans, is it the altitude that needs to be set? I always do and not had a issue in the same planeSorry if this has already been mentioned, but is autopilot bugged or am I doing it wrong?
I'm completely new to flying and flight sims, and have been mainly flying the Cessna 208 Grand Caravan. In the flight plan menu I choose a route, select low-altitude airways and choose the approach I want etc. I take off and then climb to cruise altitude, but then I turn on autopilot by pressing AP and then I press the NAV button, but the plane decides to instantly turn into a downward spiral and ends up breaking. Am I doing it wrong or is it just bugged? The flight plan is loaded in the Garmin as well, I checked that.
)Sorry if this has already been mentioned, but is autopilot bugged or am I doing it wrong?
Autopilot is very bugged. On the GA aircraft I struggle to get it to engage and I just had an instance in one of the Diamond aircraft where hitting VS as I climbed didn’t pick up the rate and instead barrelled into the ground.
With regard to sensitivity and deadzone, it seems not to matter where you set these as soon as the joystick hits the first contact spot there’s the wild over control. It’s almost as if the game is seeing it as digital rather than analogue.
