 - 22 Jul 2014
 - Oxon
Bit more tweaking - (I know you're probably all getting tired of my posts haha).
Looks like 16GB DDR4 3200MHz makes a big difference over 16GB DDR3 1600MHz - I still don't think 32GB is necassary unless you're trying to play with all settings maxed out.
Whilst during the initial loading screen, usage can spike up to 99%, it then quickly settles back down to what you see above.
Average frames are now 30fps on the ground (both internal and external) (KSEA), and up to around 50fps in the air:
And loading into NY:
Even here RAM usage settles down after a few moments:
This is 1440p in the settings, with render scaling down to 80 (1152p). Leaving it at 100 knocks off around 10fps from the averages. The rest of my settings are as per here: https://forums.flightsimulator.com/t/how-to-graphics-settings-and-performance-guide-8-18-2020/132407 except I also have my Level of Detail sliders at 80 for both. V Sync off. Live weather, time and traffic at default levels.
 then it dropped to 10.5GB of Vram
