Deleted member 87287
							Loving some of the new aircraft liveries 40+ 3rd party ones so far
 I think I'll wait til then before really getting the playtime in
 I think I'll wait til then before really getting the playtime inHave you tried signing out and then back into your xbox & Microsoft accountsStill can't get it to reinstall, so many restarts, and initial downloads. Sick to death of clicking any key and then the it just hangs.
So frustrating after what was a perfect initial install and system that was running it absolutely fine (3900x, 32gb ram).
Oh well. I just resort to looking at the lovely pictures for now.
https://www.flightsimulator.com/known-issues/Still can't get it to reinstall, so many restarts, and initial downloads. Sick to death of clicking any key and then the it just hangs.
Stuck on "Press a key to continue"
Follow
Support Updated : Today at 22:40 Tuesday at 16:39
If you're stuck on a black screen, please do the following:
Install the English (United States) Language Package and reboot your computer
Microsoft Flight Simulator requires the English (United States) Language Package. To install a new language pack on your system, follow this link: Language packs for Windows
Unplug your USB devices
Unplug any non-essential or ALL USB devices that may be plugged in. Once in-game, plug your USB devices again.
Run Microsoft Flight Simulator as Admin
To do so, type "Flight simulator" in the Windows search bar then select "Run as administrator" in the menu.
Deactivate Windows Defender and/or your firewall
- Open Start. . ...
- Open Settings. . ...
- Click. Update & Security. ...
- Click Windows Security. This tab is in the upper-left side of the window.
- Click Virus & threat protection. ...
- Click Virus & threat protection settings. ...
- Disable Windows Defender's real-time scanning.
- Set game priority to high
- Turn off any overlays
Check that your antivirus is not causing a conflict with the game
Sample of Virus checkers that have been known to prevent games and apps from launching:
- Trend Micro Maximum Security
- Comodo Antivirus
- Sophos
- Emisoft Anti-Malware
- Avira
- Avast
If your antivirus falsely flagged Microsoft Flight Simulator, remove the file from quarantine then whitelist Microsoft Flight Simulator. To do so follow the instructions from your antivirus manufacturer.
Reinstall the App from the Microsoft Store
- To do so, type "Flight simulator" in the Windows search bar then select "Uninstall" in the menu. Click twice.
- Open the Windows Store app
- Go to My library, search for Microsoft Flight Simulator
- Click install
Additional troubleshooting
- Make sure Windows has the latest updates: Select Start , then select Settings > Update & Security > Windows Update > Check for Updates.
- Disable Nahimic service or Nvidia Sound Devices in Start Up Task Manager while performing a clean boot – To do so, simply follow the instructions from the Microsoft help-center: https://support.microsoft.com/en-us/help/929135/how-to-perform-a-clean-boot-in-windows
- Follow this guide.
Welcome to PC gaming where these kind of problems are what makes it so great compared to Console gaming were you just stick a game in and it works, There no fun & stress in thatI can but try.
Just really cheesed off as this was working yesterday and I changed nothing. It really shouldn't be this hard to run a game, or reinstall it for that matter.
Im just waiting on my HOTAS warthog on a pre order then ill need to uninstall/Reinstall as i want it on my 1TB SSD as right now its on my C 512GB drive
Just wish there was a easy way to move the game folder over like you can on Oculus and steam
If you go to Settings > Apps and click on Microsoft Flight Simulator there you get a move option
