I would say its the upgrade to the 1080 Ti at the $800 price band. And if it equals the 2080 Ti that is an exceptional jump from the 1080 Ti at that price point.
Think I'm settling on the founders edition 3090 if I can get one. Better not be anymore than $1400 -.- you'd hope it would be £1049-1099 with the exchange rate.
So its 12% reality down!!!
This much extra works!
And I foolishly thought that the FE was big but this is positively enormous.
Looks like 2.5/3 slot and I would guess around 340-360mm long. :O
Well if you look at the RTX3070 and RTX3070TI,the GDDR6X and extra shaders is only adding 30W more board power. But if you look at the RTX3080 and RTX3090,despite the latter having 2.4X the amount of GDDR6X and far more shaders,the board power is only 30W higher.
I think they are all Samsung - just the GA102 is massive,so probably is pushing the node??
Transitors are not the same - this affects power usage particularly, that's where binning comes in.
Going by the 34.5 billion transistors leak and that the 2080ti has 18.6 billion transistors. It seems to me more likely to be on 7nm somehow?
Darn it the 3080 doesn't have enough ram for my gaming, thats a second generation of card with not enough ram as my 1080Ti :/
It is not the clock speeds. It is not the memory. It isn't anything else other than the poopo Samsung GPU die.
This has been common knowledge for over a year.
I kinda feel like Roddy Piper in "They Live" sometimes. You know? where he tries to make the guy put on the glasses so he can see what is going on?
Pls. Watch.that.video.
This isn't a recent discovery. He has been saying the same for over a year about it. Everything you will ever need to know will be in that video, and has been for two weeks. All of the process issues, the processes themselves, the power draw, ETC ETC ETC.
I think the core is having yield problems,and the RTX3090 just has the best binned cores,but the GA102 in the RTX3080 is going to closer to what is actually doable in volume. It is nearly 20% cutdown.
1933 Boost Clock? 45c temp?? Seems the leaks are coming boys!
Remember that's only the 3080. The 3090 may not be as well behaved. Mind you, its cooler is much bigger so hey there may be some surprises![]()
Can you translate this pic for laymen like me? Don't have a frame of reference to understand it.
