Caporegime
- 18 Oct 2002
Gibbo has stated before that the sterling/dollar rate has to be around $1.35 for the straight conversion to happen (VAT, other costs). We're slightly below that atm...
Just realised my Antec/Seasonic TP-650 is 10 years old in a couple months.
"Supposed" to replace them after a few years anyhow, or so I thought.
I honestly don't think my 1080Ti can actually *use* all 11gb of RAM.
Try some modded games,with ENBs and run them at 4K with 4K and higher resolution assets.
Let me put it another way. Do you think my old GTX 560 would have any use for 11gb of vram?
I do not think it would.
My GTX1080 had more than enough grunt to run the game. But when it ran out of VRAM,the FPS tanked.
The VRAM was teetering on the edge of 8GB under DX12. The moment it went slightly over 8GB of actual usage the FPS literally halfed and the game was also more stuttery if I panned.
I think it was fixed later on,but a lot of what people think is the GPU running out of grunt can be VRAM limitations.
Your GTX1080TI can use all 11GB,as texture mods are not reliant on your GPU. I run modded Fallout 4,which is capped at 60FPS. With some of the 4K and 8K,etc texture mods,once it goes over 8GB,performance shows the same crashes.
GPU utilisation was nowhere near 100% in those scenarios with a GTX1080. The GPU wasn't the problem,the amount of VRAM was.
If I had a GTX1080TI,I would see more consistent performance at qHD due to VRAM.
Your chart has no explanation for the different color traces.
And you never answered my question. Do you think my old GTX 560 could use 11gb of vram?
my msi afterburner
Just thought. All of the rumoured prices for the cards are in $. Are we expecting it to be a simple £/$ swap? IE $1400 becomes £1400?
With the release of the Zen3 CPUs I've decided on a total rebuild anyhow. It was always going to be CPU/Mem/Mobo, with a PSU that old might as well do the full monty. Helps that I'm not fond of the current caseThat old chestnut, heh.
I've got an Antec Neo 550 fully modular PSU that is from 2007 in the system sat near me, it has been running almost 24/7 for 13 years, and it's not had an easy life when it comes to load. Very few on/off cycles and a constant(ish) temperature is probably the main reason it is still rock solid, that and it gets cleaned out with an air compressor every 6 months.
There seems to be this pervasive misunderstanding that vRAM is chosen to future proof the card against what up coming games will demand, and that's wrong. The purpose of vRAM is to feed the GPU data to do work on, you can't just keep loading data into the game world without impact to your performance. If there's a floor to GPU performance (min acceptable frame rate) then there's an equivalent ceiling to useful vRAM. The amount of vRAM to put on a card is directly proportional to the amount of work the GPU can do, thats how you make vRAM decisions. With probably the exception of cards aimed more at CAD or doing other non-gaming things like professional rendering.
The dollar price is usually without sales tax etc so there's that, plus we have VAT to add in the UK at 20% which usually means a 1:1 ratio like you say![]()
OK. If preorders are live tomorrow, who is actually buying a 3090 FE and what's the most you'll pay?
I will be at a maximum of £1399.
Yeah im just hoping for a cheaper releaseThough i certainly don't expect it will happen!
Damn Sunak. Why didn't he reduce VAT on graphics cards as well. I don't mind not eating.. at least I'll be warm.
I really doubt there'll be any pre-orders tomorrow.
Have there ever been pre-orders before any reviewers even have the cards?
Unfortunately, I'm expecting Nvidia's new cards to be more expensive than the 20 series, with everything moving up by £50-100 depending on which tier![]()
Of course it could, if there was any software which took advantage of it.Your chart has no explanation for the different color traces.
Same people will swear up and down that water isn't wet if you had that position before them. Totally impervious to evidence to the contrary.
I don't think you understand how VRAM works. 11GB of data isn't being used constantly, it's stored there because it's quicker than accessing it from system RAM. No different than having data in system RAM vs getting it from disk or SSD.
I honestly don't think my 1080Ti can actually *use* all 11gb of RAM. I just don't think the GPU and bus can move that much data quickly enough.
We need some sort of metric that compares GPU "power" and Vram bandwidth, to find the cutoff point for capacity.
We all (instinctively) know there's a point where the GPU can't use an infinite amount of vram, but I don't think I've seen a reliable way to calculate where that point is from one card to another.
