Do what us Vega boys been doing for a while - undervolt, dial it in.
If only I was that smart not to balls it up :/
Appreciate the confidence, saves having to pay £120 on an 850w just for an overpowered card I'll be using at 1440pIts really simple you will be fine.
my 3700x is at stock, not sure how power hungry it is, not even sure why i got this cpu over the 3600 lol
so you think a ASUS 3090 for £1589 is good value against Nvidia offering the same 3090 for £1399![]()
Appreciate that, wish I knew the weight, I'm always anxious with that card weight, current got a vega 65 strix installed and thats pretty damn heavy.Then you'll be fine, even if you overclocked the 3080 650w is enough
So what gpu you upgrading to? Waiting on amd?I suspect Asus's 3090 offerings are as good or better value than their 2080Ti offerings were.
I never thought the 2080Ti was worth the price, so I didn't buy one. But If I had thought that the 2080Ti was worth it, I don't see how I could be mad about the 3090. Generation over generation, It offers more of a performance increase for less of a price increase.
It's the hysteria that gets me. Jen is so good at making people think what they have is a load of crap.
To test this theory I allowed the virus that is COD MW to mutate and give itself 20gb more storage. I used all of the new settings, including the shadow maps and etc. Even used RT.
It looked superb, and at 1440p I was hitting around 150 FPS. So the performance has actually improved since I played it last, with more stuff enabled.
I can't see BLOPS 4 Cold War changing this very much, so the only thing I am left to worry about is Cyberpunk. Though what I really mean is that "worry" is actually a lime and I am just bitter.
the official specs are 750w for 3090 and 3080 and 650w for 3070 BUT the footnote says based on pairing with an 10900k and other cpu combinations may have a lower requirement. (see the nvidia site and the full ampere specification lists)
Dat doom performance though.
That's normally how it goes with tech though.
My 1080Ti isn't worth much, and the 3080 I'll probably end up getting will be worthless eventually too.
awful IIRC.What where the 2080FEs like for noise?
