I do wonder how much of an effect it will have on air coolers in ITX cases (such as the NR200), and whether having generally good flow in the case will mitigate it somewhat. Having just bought an NR200 (waiting on delivery) and eyeing up the 3080 to replace a 970 loaner, I'm more than a little concerned.That is going to suck for mini-ITX systems!
Also,I hope people have decent CPU cooling,that hot air is being dumped right onto the motherboard!
Ryan Smith from AT made some performance/watt calculations:
The problem is the board power is between 320W~350W for the RTX3080/RTX3090. This is not something that I would want in Ghost S1 or something like that!
I think waiting for RDNA2 next month might be prudent,to see if they have delivered on their efficiency claims. Either that or get the RTX3070 which is rated at 220W board power.
2080ti's are now selling for $600usd on ebay
Turing was really good at underclocking. People with ITX can do that if they wish - for example you can make a 2080ti draw 60% its normal TDP for just 20 to 30% performance loss - if that transfers over to Ampere then you can cut a 100w to 150w off the TDP of a 3080/3090 and it would still be significantly faster than the 2080ti
To those who still bought a 2080ti for $1200 after being told it would be a paper weight once ampere was released I ask you...Can you still afford it to go 3090 without having to sell 2080ti?
3080 Ti will probably be £1k.
Will be spec'd only slightly below the 3090.
I'm guessing yields for the 3090 on Samsung 8nm is terrible right now. 3080 allows the careful fusing off of bad die area.
You buying the 3080? It will be much better than the Titan XP. Like double I think.
Thanks.
Pricing seems to suggest to me that they're worried about amds offerings which can only be good news for us consumers!
