- 19 Jan 2006
Urgh, cooler is upside down.
I believe it's just a sticker, so I probably could peel it off and stick it the right way round - but that's effort! It's behind a non windowed side panel, so I'm not overly fussed.
Its a shame, there simply looks to be no room to mount it the right way round.
Correct, size constraints on the case mean it has to be mounted that way. If I could mount the rad to the front and then the fans inside the case then it may have been possible, but the rad is slightly too long to accommodate that due to the front panel IO.
That seems like a beastly rad for a CPU
280mm rad, on a 9600k
