I can't see any way for it to easily come off unfortunately but thanks for the suggestion!If its been put up by countersinking holes, screwed and filled you could run a magnet down it to try and find the screws.
Have you thought about getting an 'intu' blind which clips in behind the glass? I have them in my ensuite, master bedroom and kitchen patio doors and they work really well. Easy to remove if you ever need to as well.Thanks @Gary* I've already got the first coat of grey gloss on. All of the other banister grey bits have just had their second coat, looks good atm. Will look even better when the grey carpet goes down too.
@HungryHippos Looks great budHave you thought about getting an 'intu' blind which clips in behind the glass? I have them in my ensuite, master bedroom and kitchen patio doors and they work really well. Easy to remove if you ever need to as well.
When I first opened this post I thought you were going to say "put some tiles up" or "finished grouting" and I was going to say well done that looks really nice, but Im also a big fan of cleaning.I had my bathrooms done almost a year ago along with other stuff in the house.
Today decided it was finally time to clean my tiles properly as the fitters had only done a cursory job.
Went over every tile in both bathrooms with hot water and a micro-fibre cloth, got as much of the leftover grout and things off as I could. Wish I did it sooner really as the result is even better than before!
Next up will be installing the blinds, can't easily drill through those tiles so I'm hoping I can affix to the window frames instead.
En-suite:
Main Bathroom (weird shape hard to get in 1 pic):
Some of the grout in the main bathroom appears to be discoloured, not sure how to fix it. It's meant to be quite a uniform light grey colour like the ones on the floor.
So well done that looks really nice.![]()
I already bought the blinds they've been sat in boxes in my kitchen for a couple of months!
If they don't work out for some reason I'll look at the Intu ones. These should mount to the window frame OK but the tiling has removed some of the available window frame space.
Electrician is starting work on the CAT6 and power runs soon so that will be good, tomorrow based on what he said. That will leave a bit of fixing up to do so I'll probably use the "DIY" mode status to tackle the blinds as well, right now i'm in cleaning mode, think the house is about as clean as it's ever been!![]()
Do you have some left over paint to make any touch ups if needed? I am really neat when installing new socket locations but I still find I end up needing to decorate around them before I am happy.No but I need to get some more paint anyway as some touch up work to do, and some more gypsum as well.
My robo vac fell down the stairs a while back and took a chuck out of the wall so got that to fix up too!
How much were your blinds if you don't mind Mr Hippo? They look spot on. Sleek, minimal and still block out lots of light.
Any pics yet @HungryHippos?SweetAny pics yet @HungryHippos?
Bovis homes decided to use plasterboard instead of blocks![]()
What is that supposed to be?
