Estimate time remaining is an hour.
Works in Hyper-V so should be good for Feek.
Probably be done here in a few mins 4 gb uploaded of 4.91 2004 august update.
Or not it uploaded and I dont have enough space lol
I missed the 1Gb upload in your last email.
You go for it.
I had to request access so I think you need to approve.
I'll have a look, thanks.@Feek for future reference here is what I believe we all did:
Yup, it's downloading. Thank you.DONE I THINK
It's a combined download containing both Windows 10 Home and Professional. I don't want that, I only want Pro on the image.
Thanks, I've got your message but as per above, that looks like a combined image with multiple versions.
Got it, thanksDone I think.
Got it, thankslet me know when you have it so I can get rid![]()
Grabbing it, thanks.Used ImageX to extra Pro from install.wim on the en-gb_windows_10_consumer_editions_version_2004_x64_dvd_d4d263d8.iso, renamed and replaced the original install.wim
You're suggesting I use an OS I said I don't have access to in order to run a script? Why would you do that?Take the combined image, enter about 2 lines of script, and extract only the image you need and stop being so lazy...
The first one I burned and installed was the one just called Windows.iso which I think was yours, @Vince
It was 1909.
Now I'm writing SW_DVD9_Win_Pro_10_2004.3_64BIT_English_Pro_Ent_EDU_N_MLF_-2_X22-33663 this one to a DVD, let's see how it goes.
Not having much luck here.
The next one only had English (United States) as the 'Language to install'. The first one did have UK for all three boxes.
Now burning W10Pro.iso to try that.
It was a faff and I remember someone suggesting at the time that it would annoy them. This time it's not stupid o'clock so I'm giving the third image a try because it will annoy meSame problem as last time... you can just go us and set to uk after install. Shouldnt even require a language pack.
