I think the new 3000 series will be much faster on Raytracing but I still think the 2080ti is still going to be quite decent in none RT gaming.
Wait for reviews then? They are opening themselves up to numerous breaches of consumer protection and false advertising laws if they are lying.
There's this
Its' a doom benchmark test between the 3080 and the 2080ti and the 3080 is beating it by at least 40% - you have them shouting this from the rooftops. Yes they could have cherry picked this but like I say they're shouting this from the rooftops!
Nvidia gimping the 2080ti in that test.
Try this, now its only winning by 10%. This is why you should not buy into Nvidia's numbers, wait for real tests because a very simply overclock on air makes a 2080ti run up to 30% faster than the gimped stock numbers nvidia is using in this game
That's an overclock , how about a 3080 overclock? 'Cos now you're gimping a 3080 ,it says 3080 stock so you overclock the 3080 and then it jumps ahead again doesn't it over and above the 2080ti .
So what's so wrong about stock versus stock. They could overclock the 3080 but they didn't so therefore they compare it to a stock 2080ti.
Crazy.
That's an overclock , how about a 3080 overclock? 'Cos now you're gimping a 3080 ,it says 3080 stock so you overclock the 3080 and then it jumps ahead again doesn't it over and above the overclocked 2080ti .
This is comparing stock with stock, why would nvidia then overclock the 2080ti if they're comparing it against the stock 3080? Really you think they're playing this sort of game by allowing their own benchmark test to gimp the 3080 cos that's what it would actually be.
If they're comparing it's stock vs stock or overclocked vs overclocked isn't it otherwise you don't the cards aren't properly represented.
Nvidia really does have so many people right where they want themI keep thinking about picking up a 2080ti for the crazy cheap prices they're going for now.
Do we really trust Nvidia with the quoted performance figures?
What if the 3070 falls significantly short of the 2080ti?
I'm just wondering If I should hedge my bets and pick up a 2080 while they're cheap.
I know nobody 100% knows the answer this is just a discussion post.![]()
how you gonna oc the 3080 that Nvidia admitted hits 80c out of the box
What about rasterisation perf difference? That's still more relevant...
They got so so many people now thinking a 70 series for £470 is really cheap
And people now think £500+ for a last gen 2 year old second hand GPU is a crazy bargain price![]()
People do this every gen for some reason.
