- 23 Oct 2013
i think the backpeddle and chain slip/drop on the 50t is common with Eagle. Originally thought it was poor, but after a lot of use I realise I only really use the 50T on v steep climbs and dont backpedal. If it's something technical and I'm worried about the crank position then it's usually ok for 1/4 turn or I'm not in that 50t dishplate.I wondered that. Seems either standard procedure or misaligned derailleur. I noticed the chain fell off rather than dropped down a cog so might need a little tweaking.
Have the same groupset to go on the BluePig so hopefully will get them both shifting nicely.
Enjoy the Blue Pig, I built one myself at the end of last year. Ace bike. If you're worried about rust then get hold of some Fluid Film and spray it into the tubes (what I did anyway) after seeing: https://forums.mtbr.com/fat-bikes/anti-corrosion-product-shootout-1073581.html
how do I go about getting this voucher form you.
