If you buy direct from nvidia do they allow cooler removal or does it void the warranty?
When doe sthe NDA lfit for reviews? is it on Monday?
Just did some testing using SOTTR which is very heavy on memory usage.
Max settings 2160p.
Single RTX Titan memory used.
RTX On, DLSS Off.
RTX On, DLSS On.
Points to remember
3090 will not be able to run above settings unless it is using DLSS.
Less memory used when running DLSS which surprised me.
No, if you want to do so and be within warranty buy EVGA.
That cooler looks like it would be a pain to take off, the screws seem to be covered by little tabs.
Not sure, they don’t have any stickers on the screws so I’d imagine almost impossible to notice if you have stripped the card or not. But from experience they can be notoriously painful to take apart vs AIB cards.
Im quite tempted by the ftw3 from EVGA no ugly power connector placement and Waterblock warranty should I want to add it to my loop although wanting to go back to an air cooled GPU.
Yeah i figured, the video i watched of the kingpin card was removing old chips for higher memory speed chips i think.Does not work that way.
LOL! Some decent looking rocket pods there...
Thanks mate. Ive been looking at the FTW3 too, Ive also been looking at blocks and backplates, seems as though EK have bumped their prices since I last got my 1080Ti.
also what are the two screw holes on the end of the card?
