NVIDIA ‘Ampere’ 8nm Graphics Cards
I have been through so many different fans, the best ones I found were the be quiet! Silent Wings 3. I'm not sure if you have tried them but worth a look if you like low noise and decent performance.
yea those are fans i have and my desktop superpowered PC is quieter than my laptop and my missus macbook pro 16.
I mentioned it an earlier post, but I dislike the look of that power cable.
What were Nvidia thinking, placing it there.
The rest of the card looks fine, but that cable placement ruins the overall look.
Don't see why they couldn't have put the power plugs around the back-plate area with a short extension cable.
Exactly.
Would give a much cleaner look.
Someone at Nvidia needs to do the walk of shame for that design decision.
Exactly.
Coulda just gone with a rotated plug coming out this plate to keep it out of the way.
I'm expecting someone with knowledge of 3d printing to make a right angle 12pin piggy-back connector for the FE cards and make a fortune.
Its funny the lenghts some of go to due to pc noise, whilst others dont care at all, glad you found an easy solution. Althought I have to say I do remember some of your 900D builds and they looked very good. :)
Yes was a bit of pain but well worth it. Still have the same case now! Thanks btw :)
There's already a custom cable available on Moddiy. (Presumably a competitor so no link.) I think I'd just put some cable clamps on the card to route the cable cleanly.
Had some of those in my last build and they were excellent. I'm doing a completely new build when Zen3 is out though, so kinda just forgotten about improving my existing one :D
A week until launch and no benchmarks or reviews, no pre-orders, nerfed vram on the 3080, no decent upgrade path for 2080ti owners and a massive value loss on that card. They also seem power hungry which is a concern for 650w users and overclockers.
I won't lie, it's leaving a bitter taste giving over a grand to nvidia two years ago. My next graphics card might be an AMD, just out of spite lol
No upgrade path for 2080Ti owners?
The 3080 offers about as much performance over the 2080Ti you bought two years ago as that card did over the 1080Ti, except at a fraction of the price.
The 2080Ti was the lemon, not the 3080.
