I will be going through the soffit, went into the loft to measure up so I know where to place the hole, I just can't fit to see properly from the inside so will do it from the outside.
I'll check for slats in the soffits but I don't recall any
Fingers crossed that spider is definitely dead!
HahaI absolutely hate spiders but I just wear gloves and tell myself I’m wearing spider armour. Sad, but true.
I've got in from the outside, drilled straight up through the soffit no problem. Poked up a stiff coil of power cord and it's come out exactly where I hoped
Curious to hear people's thoughts on the security of these IP cameras. I've bought a Yi Cam on offer and would like to ensure 'hackers' are kept at bay. I read that there is custom firmware available and a note of RTSP and that it opens up FTP protocols etc etc but it's all a bit complex at the moment.
If anyone could provide a 'quick guide' I'd be all ears!
I’ve just bought and installed 5 of these.
For the price they are an absolute bargain.
Easy to setup and usealso like the recording audio option.
Haha appreciatedI've got in from the outside, drilled straight up through the soffit no problem. Poked up a stiff coil of power cord and it's come out exactly where I hoped
Had to fit the waterproof housing which involved new RJ45s, couldn't find my crimper so had to do them manually... it's been a while haha.
Kids in bed now so I can get back to it, going to tape the 4 cables to the power cord in the loft and pull them through.
Made a 32mm hole so it'll be nice and easy I hope, will grommet and silicone it up once all done
Edit: All pulled down and through without a hitch, and not a spider in sight! Just got to mount the cameras tomorrow and we're live
Cheers
Alerts are pretty much within a couple of seconds of motion
Both of my 520 have got condensation inside so I'm waiting for replacements, other than a hazy picture they seem just as good as the 410s
They've said I can keep the 2 condensated ones so once I figure out how to get them dry and sealed then I've got 2 free, if not then I've at least got 2 indoor cameras haha
I doubt they'd have such reviews if there was a 100% failure rate, I understand the sensationalism though. You get what you pay for with tech, as always.
Way easy to unmount, a simple twist and your local chancer has a nice new camera to sell.
The 410s are much better I feel, solid image quality, decent build and securly mounted.
Yes, no I understand your post.
I would hardly say they don't work as all functionality is there, just moisture I'm assuming is left over from some cleaning process. They also have a screw on top you can use to release moisture to dry it, I just prefer, as would most, to have a fresh dry unit instead of drying it out myself seeing as they are brand new.
I understand your point on quality, chinese merchandise is a slave to profitability, hence getting what you pay for. As long as the two replacement cameras have no issues then I'm more than happy with the product
Next house will be higher end for the additional functionality you get with the cost.
I'm no engineer but possibly for situations such as the one I currently havewhy is there a moisture release screw?
Your intentions are quite clear so no need to be defensive.Anyway, it’s honestly not my intention to have a go at your cameras.
Our Hikvision PTZ camera has stopped moving, we had a power cut and afterwards it didn't return to the home position. I restarted it and it tries pan and tilt check but fails both, the zoom and focus still work. I tried alternative poe power and a 12v supply but no different. I opened it up, everything looks mechanically fine, there are various voltages present, I can only see 1 fuse and it's ok, I guess the motor control circuit has failed.
I contacted Hikvision UK, they said to return it to the supplier, but we got it from an Aliexpress seller. I contacted them and asked if they can provide spare parts such as the circuit boards, they said they can't get Hikvision spares.
Does anyone have any other ideas or know of a place that repairs them?
Unfortunately no-one repairs them as far as I’m aware. They check the serial number, bin them and send you a new one. Depending on the value they often don’t even ask for them back. If it was pan or tilt that had failed I’d say look for a slipped belt but if it’s both it probably is the controller, as you’ve already worked out. Have you tried reflashing the firmware? Sometimes a hard reset and a firmware update revives them (although that’s usually on dead Dahuas).
Hey both
I am interested in getting the 520 version myself for my front door.
What is the motion sensing like? I’ve used both Ring and Nest in the past, and the delay between receiving a notification that there’s motion is far too long (bare in mind, these were both through wifi, whereas I would connect to the 520 with Ethernet).
Thanks![]()
