Has anyone got the NR200 with 280 AIO on the side panel and a deshrouded GPU sitting on 2x120mm on the case bottom? For me this gives the best cooling potential for this case.
I’d be keen to see what thermal results are achieved. I have too much time researching and planning building in this case as I can’t get one.
This is exactly my setup. I posted some photos of my build earlier in this thread but have sinced deshrouded my GPU. (https://www.gigabyte.com/Graphics-Card/GV-N207SGAMING-OC-8GC/sp#sp) I had to cable tie 2x NA-A12x25 (intake) to the heatsink as there is too much room before the bottom of the case for it to sit snug. I bought a fan adapter to connect them directly to the GPU but they just ran at 100% speed and I was unable to control it. So I ended up connecting them to the Chassis fan header. Again, the intention was to use some software to control it against GPU thermals but I haven't had the need yet.
I've not really posted thermals before so I hope this is enough information for you to make an informed decision about this setup.
3600x stock settings on balanced mode. AIO is 280mm Kraken x63 with 2x NA-A12x25 (intake). There is also 2x NA-A12x25 (exhaust) on the top panel. I have aimed for a near silent build so the fan curve is setup to not go above 1000rpm until I go over 70 degrees. Ambient, according to my weather station is 23 degrees..
Running Cinebench 20 a couple of times:
GPU temps running Heaven benchmark 2 times at 2560x1440 with extreme settings is:
I will note that I have undervolted the GPU. It is the first time I have attempted this so I am sure it can be pushed in either direction but for now I am content.
Hope that helps somewhat F1zzy
