Permabanned
- 9 Aug 2008
Could well be an altogether different issue![]()
Could well be but not serving over https could be a big issue. I'm going to test something in a sec...
Weird. CORS policy between HTTPS and HTTP ?Not in this case it isn't though surely as if it was signatures then it would show in dev tools with the link as the page is loaded surely?
I mean in this instance I'm not even logged in, cache was cleared to test and I have tested in private window just in case.
I found something that it may be related...
CORS is cross origin resource sharing - basically if website A says "Get this image here from website B" - that's CORS. It's considered potentially insecure as it could lead to malicious materials hosted on a server outside the host's control. But this is usually like, if you hotlink a webshop image from your own webpage at www.boutonaide.com. Rather than just changing protocol from HTTP to HTTPS.
I haven't read the thread so apologies if this has been mentioned but when I open the forum using the following bookmarked link:
https://forums.overclockers.co.uk/community/general-discussion.12/
It takes me to the main page which shows all the forums and ignores the fact I was logged in. This is on Edge (work), and Google (home). I suspect it's user error but thought I'd add it anyway.
Glad it's not just me. I get this funky new bar too. Thought my GPU had packed up / Windows aero was broken where you get no transparency on the start menu![]()
Same here, wonder if it is a new feature or something wrong with the forum software ??![]()
Innovation innit. That upgrade will be £5k pls and it must be done out of hours. Will take 16 hours for four developers.
Invoice email?
Is the bar staying?![]()
