A new and important part for future outdoor activities.
Look for Wahl Colour pro, I've had mine 3 years and use it for face as well as head hair
The colour pro is garbage if you want a decent cordless then it had to be the Wahl magic clip.
Mines not cordless and it's certainly not garbage
How many proper clippers have you used though?
If you don't have anything decent to compare them to then obviously a Corsa would look amazing to a novice. You would never see a pro barber worth their salt use them. Which is a sign of how crap they are.
Exactly, I got some Babyliss ones a few years ago for around £20 and they’re still great.I don't care, for the £20 I paid for them they shave my head just fine and I think I've gotten my moneys worth from them
Bought some Owatrol oil to protect the firepit/bbq.
i paid £35 for one of my wahls. you dont need to spend £100. for that extra £15 you literally get top tier vs argos clippers
I never thought I'd see the day somebody would be so elitist when it comes to ******* hair clippers, congrats
btw your pro wahls won't cut my hair any shorter than it already is so why would I want to spend an extra £15 for the same result ?
I have the super tapers and they’ve been amazing for years and years. I’ve had many cheaper models and non of them cut as well.He's actually right though. There are different wahl models and the ones with the more powerful electric motors do make a difference when cutting, much quicker and easier to use and less likely to have to go over areas repeatedly. I've got a few pairs, the super tapers are great for example.
