- 10 Oct 2010
Do you know when the NR200P is likely to come back into stock yet?
I think if I'd have not had a nearly new pair of fans to swap over to I'd have put up with the Coolermaster fans and just set up a fan curve that tends not to sit around 1k rpm (assuming that was where mine resonated, I can't recall!). For the most part, my Corsair fans barely have to spin up as they'll quite happily clear the heat from the case at low speed, it's only really when powering on my machine and the fans go to 100% for a second that I'd likely still notice the resonation.I found the same resonating thing around 1000RPM but wasn't sure if it was just me.
The gap at the bottom between the 25mm fans and the GPU is why I was considering a 120mm to 140mm fan adapter to decrease the gap with 12.7mm. But don't know if this case can fit the adapter. Anyone who do?I'm curious how the Asus Tuf turns out in this case as its the GPU I'm considering...eventually.
There is about 76mm total space for a GPU per CM website. The Asus is ~51.7mm thick. That currently leaves you with ~24.3mm. So if you deshroud it there will be more than enough room for 25mm fans...but there would clearly be a gap that you'd have to fill up with some 3d printed shrouds or something.
Everything I've read about the Asus Tuf though is its already the best performing in regards to thermals....in some cases ~15°c cooler than the Founders Edition (60°c vs 75°c). At that point is it even worth deshrouding? You might lower the sound signature a hair...but is it worth all that for a few db?
I would probably use this in case I decide to deshroud the GPU. So fans hitting eachother won't be a problem in this scenario. But thank you for clarifying that a adapter could fit!I tried to use an adapter (120mm to 140mm) at the bottom of the case with my 2-slot Gigabyte 2080ti.
It fits, BUT there will be issues of fan blades from the GPU hitting the bottom fans. It gets really tight. You could put some slimline 140mm fans in there with an adapter (or use a very thin adapter), but not the standard 25mm fans in my experience
can you post some pics of your issueHi everyone! I’ve received my NR200P a few weeks ago but I only now found the time to transplant my PC parts from a Lian li Tu150.
I disassembled everything while managing to keep the CPU cooler (Scythe Ninja 5) on my motherboard (Aorus Z490i ultra) but I immediately ran into a big issue. Because the NR200 cannot accommodate a 120mm at the back and because the exhaust fan of the cooler does need to stay flush with the back of the case, it doesn’t fit. I’ve rewatched a series of videos on YouTube and I had completely missed that detail. None of the tower coolers covered in those videos actually require having a fan flush with the back of the case, hence them fitting. I found a guy on Reddit who managed to fit a Ninja 5 in a NR200 but he only managed to do it because his motherboard doesn’t have a heatsink and so he was able to bring the back fan lower than the top of the IO shield.
I wish I had noticed it earlier but now I understand why the NR200 ships with a 90mm fan!
All medium/high performance coolers seem to have some sort of clearance issue, either with the top fans, the side bracket or the PSU mount. Should cooler master had made this case 3-5mm wider, it would have been one of - if not the most - versatile sff case. As is though and potential cooling leaks apart, I feel that this case is far better suited for water cooling.
It’s disappointing but I am considering re-transplanting everything back to the Lian li Tu150 which I believe is a better suited case for air cooling.
If anyone in London, UK is interested in a white NR200P, let me knowThis thing is heavy so I am not shipping it though!
I’ll try to post a few photos tomorrow but unlike the fuma 2 that has one of its heatsinks flush with the back of the case and the fan after that, the Ninja 5 has the fan flush and then the heatsink. There’s literally not enough space between the top of the IO shield and the edge of the case, to fit a 120mm fan.can you post some pics of your issue
you see, you literally had the same issue as me at first I was thinking of getting lian Li TU150 but glad that I didn't because of the new rtx card designs having a top fan to exhaust that hot air is a must so I recommend you keeping the nr200p
believe me you can always find a way to sort it out, I have a fuma 2 which really needs a third fan at the back if I ever want to oc, so i think I can mount 90mm fan outside the case while the cooler in exhaust position i didn't do this yet though
Well, there are three but each has its own set of compromises. The U12A touches the side vented panel and doesn’t fit with the glass panel. The C14S cannot have the fan it comes with mounted underneath the heatsink, requires purchasing a second fan and restricts the use of a top case fan. Not to mention the skin coloured fans of the Noctua coolers. The Fuma 2 seems to be the option with less compromises but it cannot handle higher TDP CPUs when overclocked.First there are a number of larger air coolers that work fine with the NR200 including the Noctua U12A, C14S and Scythe Fuma 2.
I watched all his videos multiple times and think that he is doing a great job at documenting everything and producing these informative and very enjoyable videos. I’ve reached out to him in YouTube and it turns out that he is working on thermals comparison between the NR200 and the TU150.In a video on big air cooling Sheen at Machines and More noted that the Fuma 2 was a solid cooler choice for the case and he called the C14S the "honey badger" of air coolers for this case.
Adding a few millimetres of width would still keep the case in the sub 20L category. Look at the TU150... it’s under 20L and if they were to replace the top handle with a vented panel, add more ventilation holes to the side panels and find space for 240/280 radiators, it would become the most versatile SFF case.Adding a few more mm might not sound like much but would have pulled the case out of the sub 20L category that is craved by most SFF builders.
I really believe that the NR200 and the TU150 are one of the most versatile cases, right now. The thing is that the NR200 seems to favour water cooling while the TU150 favours air cooling. None is a Jack of all trades but I agree that the NR200 is slightly more versatile, should one not need any of the larger air coolers.Right now, as is the NR200 is one of the most versatile cases for SFF building.
He did and that’s the guy I was referring to. The only reason why he managed to fit it os because his motherboard (Strix B450-I) doesn’t have one of those tall heatsinks with the embedded I/O shield. This way, he was able to drop the back fan just enough to make it fit. I am about to post a few example photos so keep an eye on the thread.But....this guy fit a Ninja 5 with both fans...
https://www.reddit.com/r/sffpc/comments/ib24sc/nr200_with_big_air_cooling_build_log_in_comments/
what about noctua nf-a9x14 chromax, its only 14mm it can barely be visible.@bwarr1or
Like @far from home says, you can try with the fan on the outside, but that does mean you'll have an ugly fan outside the case instead of neatly inside. Can you not mount the 92mm fan on the case instead? Or does the CPU get too hot with the 92mm fan instead of a 120mm fan?
