Update : After seeing Memtest errors, I investigated my RAM to see if they were the culprit for the stuttering and ran the Memtests for each individual stick. Strangely, although I initially got errors, I took out the ram sticks and put them back in and I got no errors in the following Memtest, honestly feels like I am going down a massive rabbit hole.
In either case, I tested the stuttering for each RAM stick individually and found that the stuttering was present for each stick, so I have ruled out the possibility of faulty RAM sticks causing the stuttering and that it's something else.
Not sure what to test anymore, I have checked SSD health, tested my RAM, tried DDU installation for GPU drivers and different cables for the GPU. Temperatures are normal, everything looks normal.
Although I cannot scientifically rule out the PSU as the faulty for the stuttering, I am fairly certain it's not the cause of the stuttering as the stuttering is only for the first minute or two of starting a game / joining a map and afterwards the performance is flawless (I think this is also indicative that the temperatures are not the cause), so it definitely feels like a driver issue for my particular setup / faulty card.
The good news is that I believe my issue is unique and not representative of the cards performance as lots of people commented using the same card and having good performance and no issues. People who have pre-ordered this card should feel excited to get their hands on it!
Bit flipping in normal ram would just cause instability rather than stutters, Vram is different because it has a form of error correction. Avoids the crashing (as long as rate of errors is low enough) but can hit performance instead.
Another issue has now arisen with partner cards caused by the manufacturer using cheaper capacitors on the power supply, causing it to crash when it tries to boost.
https://www.igorslab.de/en/what-rea...tabilities-of-the-force-rtx-3080-andrtx-3090/
I read about that, apparently this is a unproven theory at the moment, it could well be just the AIB's pushing chips past their stability, in the previous 3 generations this has happened, a board partner doing a shipping O/C that the chip cannot handle. I think their testing is not rigorous enough, and that is if it even existed, they might have just "assumed" the chips can handle it.
